Turck
Magnetic field/temperature sensor with IO-Link
The 'CMMT' 3-axis magnetic field/temperature sensor with IO-Link is the third sensor type that Turck has developed specifically for easy-to-use condition monitoring applications - alongside the 'CMVT' vibration/temperature sensor and the 'CMTH' for humidity and temperature measurements.
© Turck
With the CMMT, the combined measurement of magnetic field and temperature enables the detection of faults on motors or in processes with magnetic components. In addition, the sensor also opens up applications such as non-contact detection of the rotation and movement of metal objects without visual contact. Due to its sensitivity of 5 µT, the sensor also detects the earth's magnetic field, but this can be masked out by parameterization if required. The device outputs measured values individually or as a vector sum via IO-Link. Users can also assign two independent switching outputs. The CMMT supports the Smart Sensor Profile 4.1.4. Users are supported by the Magnetic Field Monitor app from the Turck Automation Suite (TAS) when commissioning the sensor.
Turck
Paving the way for Industry 4.0 and IIoT
Automation solutions from Turck support the profitability, efficiency and sustainability of machines and systems. In this way, they not only increase competitiveness, but also contribute to more environmentally friendly production and intralogistics.
Turck
Multitool for the IIoT
With the IIoT platform 'TAS', Turck promises an easy-to-use and standardized overall solution for the commissioning and management of Turck devices in industrial Ethernet networks, from the sensor to the controller. The tool celebrated its premiere...
Turck
Paving the way for digital transformation
