a.b.jöddenWorking at temperatures from -40 to +120 °C
A.B.Jödden offers inductive displacement transducers and fine probes for measuring displacements of up to ±10 mm with resolutions in the µm range. The plunger of the fine probes is pressed into the rest position by an integrated spring or, in the case of larger measuring travels, by an external spring.
© ADDI-DATA
PCI-Express multifunction counter card
The APCIe-1711 has four independent and reprogrammable function modules and is compatible with many incremental interfaces: Biss, Endat, PWM, SSI, ...
- Precision and speed
- Reliable in harsh industrial environments
- Flexible application possibilities
