Product innovationsNews from the field of sensor technology
In the smart factory of the future, nothing will work without sensor technology as the 'bottom floor'! Sensor technology remains indispensable as the basis of industrial production systems. Computer&AUTOMATION presents current trends in the field of sensors in a series of images.
11 of 11
Nesos from Jumo
© Jumo
With the Nesos product series, Jumo is launching devices for level measurement using floats and reed contacts and for level measurement using floats and reed chains. In the devices, a float with integrated magnet switches one or more reed contacts via its magnetic field as the level rises or falls. Measurement is possible in liquid media regardless of foaming, conductivity/permittivity or pressure conditions. The devices can be used for point level measurement in the temperature range from -52 to +240 °C. They offer a switching point accuracy of ±2 mm. The installation of a temperature switch and a Pt100 or Pt1000 temperature sensor is possible as an option. The switching process is contactless and wear-free without auxiliary energy. The devices also offer a quasi-continuous standard signal from 4 to 20 mA and a temperature range from -52 to +200 °C for level measurement. The resolution is up to 5 mm. Variants with Pt100 or Pt1000 temperature sensors are optionally available. Approvals for shipbuilding and/or explosion-protected areas as well as a certificate for the Pressure Equipment Directive (PED) are available.
11 of 11
