Current productsNews from sensor technology
What would the smart factory of today and tomorrow be without sensors? Sensors are indispensable as the basis of every industrial production system. Computer&AUTOMATION has summarized current trends in a picture gallery.
15 of 16
Pressure sensor EDS 824 from Hydac Electronic
© Hydac Electronic
Hydac Electronic is expanding its IO-Link portfolio, which includes sensors for pressure, temperature, level, humidity, oil ageing and oil contamination, and is introducing a 2-in-1 pressure sensor. The compact EDS 824 pressure sensor monitors the system pressure and the internal device temperature. In standard IO mode (SIO mode), the sensor works as a pressure switch with two freely configurable switching outputs to which either pressure or temperature can be assigned. In IO-Link mode (SDCI mode), the system pressure is provided cyclically and the device temperature a-cyclically on demand as an ISDU (Indexed Service Data Unit). The separate switching output can still be parameterized as required with pressure or temperature as the source variable.
15 of 16
