Current productsNews from sensor technology
What would the smart factory of today and tomorrow be without sensors? Sensors are indispensable as the basis of every industrial production system. Computer&AUTOMATION has summarized current trends in a picture gallery.
11 of 16
SL-T series from Eddylab
© Eddylab
With the SL-T series, Eddylab is expanding its portfolio in the field of inductive sensors. This series is a variant of the "SL" sensor series with a robust spring probe mechanism. The combination of a hard chrome-plated plunger with a diameter of 6 mm and precision bearings in a stainless steel housing with a diameter of 20 mm ensures high resilience, particularly with regard to lateral forces. The measuring ranges extend from 10 mm to 300 mm. Three different operating modes are available. An integrated tension spring ensures that the plunger extends. Furthermore, two pneumatically activated designs are available for automated measurements, the plungers of which either retract or extend when compressed air is applied.
11 of 16
