ipf electronicMeasuring flow rates in pipes
With the 'SM89x-SM9xx', ipf electronic is launching a new series of magnetic-inductive sensors made entirely of stainless steel.
5 of 14
© ifm
ifm offers intelligent power supply units that provide the required voltage directly on site. The power supply units comply with protection class IP67 and can be installed together with other components on the machine or system. Integrated electronic fuses in the power supply units protect the 24 V power supply against overvoltages and short circuits. The output voltages and rated currents of the individual circuits, for example, can be set via the IO-Link interface of the power supply units. Current values for voltages and currents of the individual circuits, input voltage, operating hours, internal temperature, etc. can be read out via IO-Link. The power supply units are available in two versions with a three-phase or single-phase power supply on the input side. The three-phase device has four output circuits whose maximum current can be set to up to 12 A. The single-phase device has two output circuits with up to 4 A each. The rated outputs are 500 W and 300 W respectively.
SPS 2022: Hall 7A, Stand 302
5 of 14
