Current productsInnovations in sensor technology
What would the smart factory of today and tomorrow be without sensors? Sensors are indispensable as the basis of every industrial production system. Computer&AUTOMATION has summarized current trends in a picture gallery.
3 of 13
Precision pressure transmitters from STS Sensoren Transmitter Systeme
© STS Sensoren Transmitter Systeme
With the ATM.mini, STS is launching a precision pressure transmitter that reliably measures pressures up to 100 bar with a measuring accuracy of 0.5 % total error over a temperature range of -40 to +125 °C. The ATM.mini device offers this precision with the help of the optionally available 'burn-in' process. The robust stainless steel housing and the overpressure resistance ensure durability even under harsh conditions. The transmitter weighs just 50 g and has external dimensions of 17.5 mm x 49 mm. A variety of process and electrical connections offer flexibility. For the output signal, users can choose whether the measured values are transmitted via a current signal (mA) or a voltage signal (VDC).
3 of 13
