Pepperl+Fuchs
From standard to special development
The individualization of products and systems is one of the key topics in the industry. During a press conference at SPS 2019, Pepperl+Fuchs presented a customer-specific sensor solution developed in close cooperation with a shuttle manufacturer.
Thanks to five measuring beams, the MSH5 shuttle is able to reliably detect shuttles in front as well as interfering objects at all times.
© Computers&AUTOMATION
Pepperl+Fuchs has been developing individual sensor and interface solutions tailored to customer requirements for decades, and some of today's portfolio products originate from customer-specific projects. With current examples, the company now wants to communicate the topic even more clearly to customers and interested parties.
Montratec manufactures modular monorail systems for internal transportation tasks and assembly processes. For the current shuttle generation 'montrac Shuttle MSH5', the previously used sensor technology was to be replaced, as this was based on a one-dimensional, optoelectronic sensor with energetic signal evaluation. This means that it emits a simple switching signal and detects shuttles in front via a single light beam. This means that it is not possible to differentiate between fixed track sections such as tunnels or shuttles in front, nor is it possible to negotiate curves without additional sensors on the track. This was to change with the new generation of shuttles.
The starting point for the development was to rely on a measuring technology so that distance values could be output that could be used for further processing. This is where 'Pulse Ranging Technology' (PRT) from Pepperl+Fuchs comes into play - a pulse time-of-flight method that measures distances from a few centimetres to several hundred meters with millimetre precision using a direct measuring method. PRT is used, for example, in the 2D LiDAR sensor 'R2100', which was used as the basis for the sensor solution for Montratec.
Pepperl+Fuchs describes the adaptation of PRT to the conditions in the shuttle as the greatest technical challenge - both in terms of design, hardware and software. A production line including special calibration and testing equipment was set up especially for the project.
The housing of the sensor was specially tailored to the shape of the shuttle, which required a completely new design of the measurement electronics: individual sensors now provide distance and intensity information from five different measurement points in a semi-circular, geometric arrangement. As the multi-channel sensor solution had an impact on the measurement evaluation, software adaptations were necessary.
Thanks to the five measuring beams, the new MSH5 shuttle has an additional, peripheral field of vision and can therefore reliably detect shuttles driving ahead as well as interfering objects at all times - on straight stretches as well as in curved situations. In addition to improved monitoring of the route and the associated optimized collision avoidance, the wider beam angle of the five emitting LEDs also enables wider workpiece carriers to be transported. If a sensor is also used at the rear of the shuttle, reverse travel can also be monitored by sensors.
OPC UA
On the way to the world library
The vision has been in place since the end of 2014: OPC UA is to achieve the status of a globally recognized standard for the Industrial Internet of Things IIoT by 2019 at the latest. During the press conference at SPS, the Foundation took a stand...
Turck
More investment in software expertise
The economy is leaving its mark: compared to the previous year, Turck expects total sales of around 640 million euros for the 2019 financial year, a decline of 3%. Nevertheless, Managing Director Christian Wolf is optimistic.
SPS 2019
A look back at the fair
The 30th SPS was the highlight of the automation industry at the end of November. The keywords 'digitization' and 'digital transformation' were visible right through the halls. The main trends can be seen in the film below.
Video
SPS 2019 in retrospect
The 30th SPS, the trade fair highlight of the automation industry, took place at the end of November. The buzzwords 'digitalization' and 'digital transformation' were visible throughout the halls - the most important things in the film.
Sieb & Meyer
Dynamically driving high speed motors
Under the name SD4x, Sieb & Meyer is developing a new generation of frequency inverters for high-speed applications. The first of these is the SD4S version, which is designed for small high-speed spindles and motors with a power output of just a...
IniNet Solutions
Industry 4.0 'off the shelf'
iniNet Solutions has developed an automation architecture based on web server-supported SCADA and programming software, which is intended to bring manufacturing companies more easily than ever to industry 4.0 level. This architecture can be seen at...
CloudRail
Plug and play into any cloud
A year ago, Cloudrail unveiled the 'CloudRail.Box' for the first time - a gateway that connects plug-and-play to IO-Link sensors and masters and sends the data to any cloud platform. Now it also handles OPC UA and Edge Computing.
R3 Communications
Manufacturing without cables
R3 Reliable Realtime Radio Communications presents its first series products "Echoring Ethernet Bridge" (EREB) and "Echoring System on Module" (SoM) at the SPS. They are intended to complement wired industrial Ethernet networks with equally powerful...
