Leuze
For optical compartment fine positioning
With the IPS 400i camera-based positioning sensor for storage and retrieval machines, Leuze electronic is expanding its 'IPS' series with a variant for optical compartment fine positioning.
© Leuze
The sensor detects circular holes or reflectors not only in single-deep but also double-deep racking and thus determines the position deviation in the X and Y directions relative to the target position. This makes it particularly suitable for double-deep pallet high-bay warehouses.
A version with integrated heating is available for use in cold stores down to -30 °C. Commissioning is carried out using a web-based configuration tool with a user-guided installation wizard. Printed parameterization codes are read in without a PC via a 'code generator', enabling configuration adjustments to be made directly on the storage and retrieval machine.
An alignment system with four feedback LEDs further simplifies commissioning.
Thanks to its IR LED illumination, which is independent of ambient light, trouble-free use in warehouse technology is possible with just a single device for a working range of up to 2400 mm. The sensor from Leuze can be integrated directly into the network environment via the Ethernet TCP/IP interface and Profinet RT. Condition monitoring and predictive maintenance are carried out via a quality indicator that detects a deterioration in the reading performance of the sensor at an early stage.
Leuze
Two principles in one device
According to the manufacturer, the GSX combination fork sensor from Leuze combines the advantages of the light and ultrasonic versions and is particularly suitable for labeling machines in the packaging industry.
Leuze
Subsidiary founded in Poland
Sensor manufacturer Leuze is now selling its sensor solutions on the Polish market through its own sales and service company Leuze electronic Polska, based in Katowice, southern Poland.
Fraunhofer IPA
Calculated leakages
Using calculation to generate compressed air leaks in a system was an unusual requirement for the compressed air and pneumatics specialist Mader, which commissioned Fraunhofer IPA to visualize the effects of compressed air leaks live.
