Leuze electronic
Focus on safety
A striking feature of the Leuze trade fair stand - otherwise traditionally kept in the corporate color red - is a yellow wall this year. The intention behind it: To draw attention to the sensor manufacturer's safety products and solutions.
Ulrich Balbach: "We support our customers throughout the entire life cycle of their machine or system, for example with risk analyses, safety inspections or follow-up time measurements."
© Leuze electronic
Leuze electronic sees itself as an expert in the field of Safety@work, explained Managing Director Ulrich Balbach at a press conference at SPS IPC Drives, and offers its customers complete system solutions - starting with the safe 'MSI' controller in the control cabinet, through safe sensors - light curtains, scanners, switches and guard locking devices - to the matching safety services. Customers are supported throughout the entire life cycle of their machine or system - be it with risk analyses, safety inspections or run-on time measurements.
Based on the 'MLC' safety light curtains, 'Smart Process Gating' has been developed as an alternative to the muting process that does not require any signal-emitting sensors. Material must be fed in and out at conveyor system access points, but people must not be able to enter the hazardous areas. For this purpose, safety light barriers are installed at the access points. The muting method is often used to ensure that only the material can pass through the light barrier. Specially arranged sensors detect the material and allow it to pass through. 'Smart process gating' uses a signal from the control system and the interruption of the light barrier for release. As sensors are no longer required, the conveyor systems can be built particularly compactly, saving valuable space.
Ulrich Balbach highlighted the 'RSL 400' safety laser scanner with Profinet/Profisafe as another safety highlight at SPS IPC Drives. These new variants can be easily integrated into industrial networks and have also been developed in a robust AIDA-compliant version especially for the German automotive industry. Another new feature is the combination of 'RSL' safety technology with a high-precision measured value output for the navigation of Automated Guided Vehicles (AGVs). When driverless transport systems work with contour navigation, the safety laser scanner can simultaneously take on the task of navigation support in addition to its safety task, and an additional sensor is not required. The device sends the measured values from the environmental scan to the navigation computer. Due to the technology used in the 'RSL 400', the measured values have a particularly high resolution and low error, which in turn enables fast and precise navigation of the vehicles.
Start-ups
The 'Automation Hackathon'
At the 'Automation Hackathon' at SPS IPC Drives 2018, seven start-ups had the chance to develop new business models for selected companies in the automation industry in 48 hours. Winner: the start-up Othermo in collaboration with Wago.
Synapticon
Entering the Machine Building Business
Known as a technology supplier to robot manufacturers, Synapticon now plans to offer targeted solutions for machine builders. The kick-off was given at the SPS IPC Drives with the ‚Actilink‘ drive systems and a quick-start package for the production...
Faulhaber
The winding does it!
With the market launch of the new brushless DC motor family BXT, Faulhaber is setting new standards in the field of external rotor high-performance drives. The winding plays a central role in this.
