TWK
Detect alignment and speed simultaneously
TWK has expanded its family of inclination sensors with a special device that makes it possible to precisely measure the current orientation - i.e. the inclination or position (360°) - and the speed at the same time in a rotating application.
© TWK
The sensor is mounted in the rotating part and does not have to be positioned centrally on the axis of rotation. The sensors used for position (accelerometer) and speed (gyroscope) are MEMS-based. The sensor is optimized for non-reversing operation.
It transmits its values to the controller via CANopen or Profinet (also Profisafe - PLd). The direction of rotation, zero point and distance to the rotary axis can be parameterized; a special version also detects the distance to the rotary axis automatically. In principle, the function corresponds to that of a rotary encoder for position and speed. According to the supplier, special filter measures suppress interfering accelerations.
TWK
ATEX and SIL2/PLd certified
TWK has a safety encoder for explosion protection in accordance with ATEX, Zone 1/21. The new generation of encoders with Profinet interface (also with Profisafe profile) is also suitable for Zone 1 (gas) and 21 (dust).
Baumer
A perfect fit in five steps
Laser distance sensors ensure process efficiency in automated production processes with the help of non-contact measurements. When choosing the right sensor, factors such as measuring range, focus, beam shape or object surface as well as ease of use...
