Endiio
Meinrad Happacher,
Award-winning sensor platform
The Austrian start-up Endiio is presenting a retrofittable sensor technology for drive monitoring at the trade fair - recently awarded a prize by the VDMA.
Also conceivable as a retrofit: Drive monitoring using the Endiio sensor platform.
© Endiio
Endiio's sensor platform forms the basis for drive monitoring, and the technology will be demonstrated on a defective drive at SPS IPC Drives. In addition to a gateway and the Retrofit Box, the solution includes customizable software and sample projects that enable industrial users, plant manufacturers and operators to easily integrate the new technology into their applications and drives. Current sensors, vibration sensors and sensors with Modbus communication can be ported to the platform.
With this solution, each sensor node acts as a router, allowing large, energy-saving and self-configuring mesh networks to be realized and IoT systems to be implemented without great effort and with little hardware, the Austrians promise. The forwarding of commands is ensured via such mesh networks. "In the patented 'wake-up on demand endiio' wireless technology, the sensors are in an energy-saving deep sleep, but can be woken up at any time if required and thus retrieve data in real time," explains Tolgay Ungan, co-founder of Endiio. Thanks to a new, patented wireless technology, the Endiio solution is said to work up to 10,000 times more economically in real-time mode than all conventional communication solutions - such as Bluetooth Low Energy, ZigBee or Wifi.
Start-ups
The 'Automation Hackathon'
At the 'Automation Hackathon' at SPS IPC Drives 2018, seven start-ups had the chance to develop new business models for selected companies in the automation industry in 48 hours. Winner: the start-up Othermo in collaboration with Wago.
Synapticon
Entering the Machine Building Business
Known as a technology supplier to robot manufacturers, Synapticon now plans to offer targeted solutions for machine builders. The kick-off was given at the SPS IPC Drives with the ‚Actilink‘ drive systems and a quick-start package for the production...
Faulhaber
The winding does it!
With the market launch of the new brushless DC motor family BXT, Faulhaber is setting new standards in the field of external rotor high-performance drives. The winding plays a central role in this.
