Sigmatek
Günter Herkommer,
Flexible with safety
Sigmatek is playing it safe. With the new hot-swap feature from the Austrian automation technology provider, modular machines and system units with an emergency stop function can be flexibly grouped or converted.
© Computers&AUTOMATION
Alexander Melkus: "With Hot Swap, safety substations can be added, removed and regrouped almost at will during operation."
With its S-Dias safety system, Sigmatek has always focused in particular on modular production machines and lines with optional modules such as loading and unloading units as well as handling and transport systems. The machine units are equipped with their own safety controller and communicate with the higher-level safety controller via the Varan industrial Ethernet. The safety-relevant signals are transmitted via Black Channel using any communication media. "With wired solutions, a single cable is sufficient for safety and standard communication. However, transmission can also be wireless, for example via WLAN," says Sigmatek Managing Director Alexander Melkus.
The hot-swap feature is new for SPS 2019. In future, it will ensure that the machine parts with their safety CPUs can be flexibly integrated into the system, logged off and logged on again at another point in the machine network - and all this at runtime. According to Melkus, the higher-level central safety controller is able to manage up to 70 optional substations with emergency stop function.
The overarching safety program is configured once with all possible participating units in the machine network and can subsequently be combined as required - just like the modular machine or line. This means that optional system modules with an integrated emergency stop function can be added to or removed from machines and systems during operation without the need for a restart. The dynamic connection is established via a simple, function-oriented log-on mechanism - without a hardware switch. Disconnection is triggered by a safe input. If a unit is disconnected from the central safety controller without first logging off, an emergency stop is triggered for all connected machine modules after the configurable watchdog time has elapsed.
In addition to the safety controller, the modular safety system in pocket format includes various safe I/Os and drives with safety functions. The 'Lasal SafetyDesigner' with its library of standard and safety function blocks, based on the PLCopen standard, makes it easy to configure the safety applications.
OPC UA
On the way to the world library
The vision has been in place since the end of 2014: OPC UA is to achieve the status of a globally recognized standard for the Industrial Internet of Things IIoT by 2019 at the latest. During the press conference at SPS, the Foundation took a stand...
Turck
More investment in software expertise
The economy is leaving its mark: compared to the previous year, Turck expects total sales of around 640 million euros for the 2019 financial year, a decline of 3%. Nevertheless, Managing Director Christian Wolf is optimistic.
SPS 2019
A look back at the fair
The 30th SPS was the highlight of the automation industry at the end of November. The keywords 'digitization' and 'digital transformation' were visible right through the halls. The main trends can be seen in the film below.
Video
SPS 2019 in retrospect
The 30th SPS, the trade fair highlight of the automation industry, took place at the end of November. The buzzwords 'digitalization' and 'digital transformation' were visible throughout the halls - the most important things in the film.
Sieb & Meyer
Dynamically driving high speed motors
Under the name SD4x, Sieb & Meyer is developing a new generation of frequency inverters for high-speed applications. The first of these is the SD4S version, which is designed for small high-speed spindles and motors with a power output of just a...
IniNet Solutions
Industry 4.0 'off the shelf'
iniNet Solutions has developed an automation architecture based on web server-supported SCADA and programming software, which is intended to bring manufacturing companies more easily than ever to industry 4.0 level. This architecture can be seen at...
CloudRail
Plug and play into any cloud
A year ago, Cloudrail unveiled the 'CloudRail.Box' for the first time - a gateway that connects plug-and-play to IO-Link sensors and masters and sends the data to any cloud platform. Now it also handles OPC UA and Edge Computing.
R3 Communications
Manufacturing without cables
R3 Reliable Realtime Radio Communications presents its first series products "Echoring Ethernet Bridge" (EREB) and "Echoring System on Module" (SoM) at the SPS. They are intended to complement wired industrial Ethernet networks with equally powerful...
