Jumo
Continuously measured
Safety PLCs are not always necessary to implement safety requirements in tank systems. In some cases, the use of safety monitors or limiters is also sufficient.
© Jumo
As a result of the devastating poison gas accident in Seveso, Italy, in 1976, it was decided to tighten the laws and regulations for the protection of people, living beings and the environment. The first result was the standard IEC 61508 "Functional safety of electrical/electronic programmable safety-related systems", published in 1998, which has been applied as EN 61508 since 2002. This standard defined the safety requirements in automation technology comprehensively for the first time. While IEC 61508 is primarily aimed at manufacturers of components for protective devices, IEC 61511 "Functional safety - Safety instrumented systems in the process industry" is relevant for operators and planners of protective devices.
The aim of all these standards is to reduce the risk to an acceptable level.
In the case of a piping and instrumentation flow diagram in plant and process engineering for the safety assessment of a process, for example, the individual components of sensors, evaluation electronics and actuators must be considered separately in order to find a general solution approach. The sensors measure physical process variables such as temperature, level or pressure and convert the measured value into a standard signal. Control units are generally used for the evaluation electronics, which convert, linearize, store and process the process variables according to rules and then forward them to the actuator for execution. Actuators can then intervene in the process sequence by adjusting functional variables of various kinds.
Two approaches
Safety-related variants can be implemented in the evaluation electronics using two approaches: One approach is for users to rely on a programmable safety controller. This solution is particularly suitable for special plant construction with a process control system and is characterized by extensive functional applications as well as a high signal density and number of signals. However, complex programming applications are required here; in addition, the inputs and outputs are tied to card types and multi-channel capability. The investment costs vary depending on the number of channels and the amount of software required. In addition, each application must be calculated and evaluated separately according to SIL. Solutions up to SIL 4 can be realized in this way.
An alternative to the programmable safety controller is the use of safety
use of safety monitors or limiters, such as those offered by Jumo with the 'SafetyM' series. Such a solution is particularly suitable for smaller applications such as special machines and individual applications with a low signal density and number of signals. In addition to low investment costs, the advantages include less parameterization work for each application. The application works with standard signals and relies on a redundant internal structure with redundant sensor inputs. Three different function outputs (analog/binary) are available. In principle, solutions up to SIL 3 are possible.
In conjunction with defined sensors from Jumo, the entire SIL chain has already been calculated and the company can issue the corresponding certificates. However, sensors from other manufacturers can also be easily connected to the safety monitors or limiters. There are also no manufacturer restrictions with regard to the actuators.
Pressure monitoring in tank systems
The 'SafetyM STB/STW Ex' safety limiter/safety monitor from Jumo is particularly suitable for smaller applications such as special machines and applications with low signal density.
© Jumo
Pressure monitoring in tank systems, especially in the chemical industry, is a highly relevant safety issue. The following shows how Jumo devices can be used to implement a convenient solution with regard to functional safety.
The core of the 'Jumo Safety Performance' concept is the 'SafetyM STB/STW'. This safety limiter/safety monitor in accordance with DIN EN 14597 has the primary task of reliably monitoring processes and setting the systems to a safe operating state in the event of a fault. The built-in LEDs K1 and K2 (red) for each channel signal that a limit value has been exceeded. The built-in relay output alarm switches the system to a safe operating state (alarm range).
The requirements of DIN EN 61508 and DIN EN 13849 are met by a device concept whose 1oo2D structure ensures the reliable detection of faults and can therefore also be used in applications that are subject to the new Machinery Directive 2006/42/EC. The 1oo2D structure is a safety model for defining the hardware fault tolerance. 1oo2 or '1 out of 2' means that the failure of one channel leads to the system being switched off, but only the failure of both channels leads to the loss of the safety function.
Matthias Garbsch is Safety Sector Manager at Jumo in Fulda.
© Jumo
As the measured value at the analog input can be recorded via various sensors or standard signals, the 'SafetyM' is also suitable for pressure monitoring. For this purpose, a differential pressure transducer is connected to the safety monitor/limiter via two Ex-i supply/input isolating amplifiers. Even with this solution, a limit value switch-off up to SIL 3 can be realized for a set level height. The user receives a compact single-channel safety controller with selectable redundant input signals for standard signals. Configuration is carried out using the device software.
The programmable 'dTrans p20 Delta Ex' is used as the differential pressure transmitter, which can be flexibly adapted to a wide range of measuring tasks. In the version with explosion protection Ex ia (intrinsically safe), it can be installed up to zone 0.
Users who connect the safety monitor/limiter to the 'mTron T' measurement, control and automation system from Jumo benefit from an increased range of functions and comprehensive visualization options. Either the binary signal of the pre-alarm or the analog output signal is used for this purpose.
Other SIL solutions that can be realized with 'SafetyM' are
temperature monitoring in heat treatment plants, the monitoring of pumps, overfill shutdowns or extruders.
Jumo
Horizontal version
The Nesos R40 LSH from Jumo is a new member of the Nesos series, which includes devices for point level measurement using a float and reed contact and for level measurement using a float and reed chain.
Jumo
Supplemented by three modules
The Varitron automation system from Jumo is being extended by three modules: The 32-channel digital I/O module offers 32 channels, 17 of which are configured as digital outputs as standard.
Siemens
The tool-supported proof of safety
The relevant standards for functional safety in the process industry - IEC 61508 and IEC 61511 - are over 1000 pages long. For users, calculating and creating standard-compliant safety verifications is a challenge. Special tools offer assistance.
Jumo
Use in hazardous areas
Especially in chemical or process engineering processes, additional heating is required to maintain or increase the temperature in order to optimize the complex processes of modern industrial plants. But what needs to be considered here?
ISH
FuSi from the modular system
The development effort for functional safety is hardly affordable, especially for small and medium-sized companies - particularly from an economic point of view. A certified safety construction kit can provide a remedy here.
