Rotary encoder
Quelle: Heidenhain | Inka Krischke,
Specially adapted to robotics
Heidenhain presents the ECI 4000 absolute inductive rotary encoder for hollow shaft diameters of 180 mm - especially for applications in robotics.
© Dr. Johannes Heidenhain
As a modular system with a scale drum and separate scanning unit, it offers robustness and accuracy as well as good mounting conditions for use in robots, according to the manufacturer. This includes direct mounting and flexible mounting options as well as large mounting tolerances. In addition, the encoder is suitable for safety-related applications up to SIL 2, category 3 PL d. According to the manufacturer, the encoder - like the ECA 4000 angle encoders from Heidenhain and WMRA from AMO - improves the absolute position accuracy at the tool center point of industrial robots by 70 to 80 %. In addition to the motor feedback, it is mounted as a secondary encoder on each robot axis after the gearbox. Here it records the actual position of each robot joint and takes into account the zero position error and the backlash. The encoder also measures the retroactive forces from the machining process on each axis of the robot arm.
Heidenhain
Long awaited
Heidenhain used SPS 2019 to present EnDat 3. Herbert Reiter, Product Manager Encoders and Electronics at Heidenhain, explains what the enhanced interface for rotary encoders, angle encoders and linear encoders can do.
Current products
News about sensor technology
What would the smart factory of today and tomorrow be without sensors? Sensors are indispensable as the basis of every industrial production system. Computer&AUTOMATION has summarized current trends from spring 2017 in a picture gallery.
