Robots
Quelle: Stäubli Robotics | Inka Krischke,
Cooperation between humans and robots
According to the manufacturer Stäubli, the robots of the 'TX2' series offer new safety functions and thus possibilities for human-robot collaboration in addition to increased performance in all aspects.
© Stäubli Robotics
The three model series 'TX2-40', 'TX2-60' and 'TX2-90' are externally similar to their predecessors, but are lighter, stiffer and have a more powerful motor, making them more dynamic and energy-efficient. In terms of safety, the six-axis models in the series have their own digital safety encoder per axis and an integrated safety board. All safety functions are TÜV-certified and meet the requirements of safety category SIL3-/PLe. Every movement of the robot is monitored by sensors. All of the robot's coordinates, speed and acceleration are recorded in real time. The series uses configurable, safe I/O modules and real-time Ethernet fieldbus systems. This enables indirect or direct collaboration between man and machine. Like their predecessors, the six-axis robots have a closed structure with IP65 protection, while the wrist is waterproof to IP67.
Drives
Common DC link coupling
Siemens is adding additional power and supply voltage variants to the Sinamics S210 single-axis servo drive system for mid-range applications. In the first new size, the system is available with an output of 0.4 to one kilowatt at 3 AC 400 volts.
Refrigerators
Also available in stainless steel
The stainless steel versions of the Blue e+ cooling unit series from Rittal have been specially developed for demanding environmental conditions, for example for applications where a high level of corrosion protection is required, such as in the...
