Product presentationsNews from M2M, remote maintenance and telecontrol
In the course of Industry 4.0, remote control - i.e. remote access to machines and systems - and the topic of M2M communication in general are becoming increasingly important. The picture gallery shows a selection of current products in this area.
4 of 10
5_CAT-1-capable LTE gateway from Westermo Data Communications for industrial M2M communication
© Westermo Data Communications
With MRD-405, Westermo Data Communications has a CAT-1-capable LTE gateway for industrial M2M communication in its range. The broadband router is suitable for remote access to SCADA systems, HMI and PLC stations and can also be used as an Internet gateway. Thanks to its compact design and voltage range of 10 to 36 V(DC), the device is particularly suitable for industrial applications. It can be integrated into networks using the built-in two-port Ethernet switch (10 Mbit/s or 100 Mbit/s). It offers uplink speeds of up to 5 Mbit/s for data transmission and a maximum downlink speed of 10 Mbit/s. Up to 5 Mbit/s can be achieved via HSUPA and 7 Mbit/s with HSDPA. The top-hat rail housing with IP40 protection features a SIM card slot that works with SIM cards such as static IP-SIM, M2M-SIM or commercially available SIM cards. Thanks to 'Connection Management', the connection is continuously monitored and many network-related problems are solved automatically without user intervention. The 'WeOS' operating system with a 'Stateful Packet Inspection' firewall and an OpenVPN/SSL VPN client provides the necessary cyber security. Functions such as static and dynamic routing, RIP, VRRP, NAT, IPsec VPN and port forwarding are also on board.
4 of 10
