TL Electronic
Inka Krischke | Tiffany Dinges,
Magnesium alloy housing
The M133K is the next generation of the 13.3-inch tablet from TL Electronic and comes with the 7th generation Core i5.
The M133K with 10-point multi-touch screen.
© TL Electronic
In many industrial, mobile applications, a tablet has to withstand extremely demanding conditions. The M133K from TL Electronic is therefore manufactured with a housing made of a resistant magnesium alloy, rubberized all around and IP65-protected. The tablet withstands shocks, vibrations and drops in accordance with MIL-STD-810G. The 10-point multi-touch screen supports hand/rain mode, touch pen and glove operation, depending on the intended use. Thanks to its design with a wide viewing angle, the display is also easy to read outdoors.
The 10,280 mAh Li-polymer battery provides up to 11 hours of battery life and can optionally be replaced during operation. A wide range of connection possibilities and options for data acquisition, communication, docking, mounting, power supply, peripherals and transportation are available for (long-term) use.
Eaton
Operation even with gloves
Eaton is adding a fully graphic touch panel from the XV102 series to the 'easyE4' product family. The 3.5-inch touch panel with color display was developed for the visualization and operation of applications based on the 'easyE4' control relay.
Rafi
Placed directly on the touchscreen surface
Rafi equips the 'Glasscape' touchscreens with haptic operating solutions: The Flexscape One and Flexscape Wheel control elements are placed directly on the touchscreen surface and enable safe function control without visual contact.
