Current productsNews about operating and monitoring
What is the optimum operating unit for industrial users? What's happening on the market? Computer&AUTOMATION presents a selection of new products from the operating & monitoring sector as a series of pictures.
The HMI Eco Touch Panels from Wieland are also available in 12.1 and 15 inch sizes. They enable seamless data exchange with the 'Samos Pro Compact' safety controller as well as with common PLCs. The screen of the robust operating devices is IP66-certified and protects the device against strong water jets and any other type of moisture. The large touch panels are particularly suitable for applications such as presses, large systems in the process industry, test benches or material processing machines where several operators are working. Their use in extreme temperatures from -20 to +60 °C can also open up further fields of application such as elevators or cold stores. Thanks to their universal interfaces and compatibility with more than 40 PLC and device manufacturers, the touch panels can be used in a wide range of applications.
