Current productsNews about operating and monitoring
What does the optimum operating unit for industrial users look like? What's happening on the market? Computer&AUTOMATION presents a selection of new products from the operating & monitoring sector as a series of pictures.
Syslogic presents an HMI system with a 16:10 widescreen display. The 10.1-inch touch computer can be equipped with different processors depending on the area of application, for example with the BayTrail processors (E3845 1.91 GHz) from Intel Atom for control applications. In future, the HMI systems will also be available with ApolloLake processors. Data is transferred to systems or machines in real time via Industrial Ethernet. If the panel computer is used as a web terminal - for example, if a PLC system is accessed via FTP - it can also be equipped with a less powerful platform such as Raspberry Pi. The HMI system can be wirelessly integrated into the network via WiFi, Bluetooth or LTE. Other features include a multi-touch surface and IP65 protection class on the front. The entire system is resistant to shocks and vibrations and is suitable for a temperature range of -30 to +70 °C. The HMI system has no rotating parts, cooling is fanless and industrial flash memory is used as storage media.
