Current productsNews about operating and monitoring
What is the optimum operating unit for industrial users? What is happening on the market? Computer&AUTOMATION presents a selection of new products from the operating & monitoring sector as a series of pictures.
12 of 12
Indicators WY050100, WP050100 and BA050100 from ipf Electronic
© ipf Electronic
The WY050100, WP050100 and BA050100 display devices from ipf Electronic are designed for a wide variety of tasks and all have a uniform design and IP65 protection class on the front. In addition to an easy-to-read graphic display (7-segment display) and easy-to-use touchscreen, according to the manufacturer, the devices offer, for example, the ability to visualize the switching thresholds defined via the signal outputs in colour with the event-dependent colour variants of the display, making them clearly visible from afar, for example for monitoring a limit value. The WY050100 is a multifunctional device and can be used as a pulse counter, tachometer, rev counter, position indicator, etc. The solution integrates an auxiliary voltage output for 24V DC for the encoder supply. The basic device with three HTL signal inputs is available with the following connection options: 3 control inputs, 16-bit analog output, 4 switching outputs and an RS232 interface. The WP050100 has an SSI input and is therefore suitable for use with single and multiturn encoders with SSI formats from 10 to 32 bits. The device can be operated as a master or slave. The portfolio of display devices is completed with the BA050100, a process display with two universal 16-bit analog inputs designed for analog signals -10...10V or 0/4...20mA.
12 of 12
