Current productsNews about operating and monitoring
What is the optimum operating unit for industrial users? What is happening on the market? Computer&AUTOMATION presents a selection of new products from the operating & monitoring sector as a series of pictures.
11 of 12
USB Type-C displays from TL Electronic
© TL Electronic
With TL Electronic's USB Type-C displays, all connections are made via a single interface and a single cable. The projected capacitive touchmonitors use USB-C technology to transmit power, video input and the touch signal simultaneously. The USB-C connection is torsion-proof. A 1 m long USB-C cable is included in the delivery. The display series is available with screen diagonals from 7 inches (17.8 cm) to 18.5 inches (47 cm) with a resolution of 1024 × 600 to 1920 × 1080 pixels (Full HD). There is a choice of open-frame installation versions or stand-alone versions with IP65 protection on the front. On request, the monitors can also be supplied without a touchscreen but with protective glass. All USB type C displays have an operating temperature range of 0 to +50 °C and can be stored at temperatures between -10 and +60 °C. The 75 mm × 75 mm or 100 mm × 100 mm Vesa interface is permanently integrated for easy installation. An OSD menu simplifies all display settings for users.
11 of 12
