Handling and assembly technologyNew products at Motek 2016
What does Motek 2016 have to offer in terms of new products from the fields of material flow, handling technology and industrial handling? Computer&AUTOMATION shows a selection of products from over 900 exhibitors in a series of pictures.
9 of 14
08_New type of dredging from RSP Robot System Products Germany
© RSP Robot System Products Deutschland
In order to control gripper modules, valves and sensors reliably and without cable clutter, RSP has developed a new type of rotary feed-through with brushless sliding contacts and smooth-running seals with low loose torque. Media such as air, vacuum, pure filtered water and electrical signals can be transmitted - as well as analog and digital video signals and all common bus signals such as Profi-Bus. According to the supplier, the ability to transmit gigabit signals is unique. The parts made of high-performance plastics and aluminum are said to enable a weight reduction of up to 50 %. All products can be mounted using an ISO flange pattern or an adaptation plate and are available in various sizes.
9 of 14
