Handling and assembly technologyNew products at Motek 2016
What does Motek 2016 have to offer in terms of new products from the fields of material flow, handling technology and industrial handling? Computer&AUTOMATION shows a selection of products from over 900 exhibitors in a series of pictures.
With RK MonoLine, Rose+Krieger presents new linear units in the upper performance segment. The roller guideways in the series are initially available in the standard sizes 40 and 80 with toothed belt drive (Z) or without drive as a co-rotating torque support (R). According to the manufacturer, the variable mounting concept can be used for almost all motors and allows the motor position to be changed at a later date. Profile grooves are intended to reduce the design effort required to attach the payload and facilitate customer-specific integration. The RK MonoLine Z can withstand loads of up to 4100 N and achieves travel speeds of up to 10 m/s with maximum permissible accelerations of 20 ms².
