Handling and assembly technologyNew products at Motek 2016
What does Motek 2016 have to offer in terms of new products from the fields of material flow, handling technology and industrial handling? Computer&AUTOMATION shows a selection of products from over 900 exhibitors in a series of pictures.
3 of 14
02_Fourdynamic series from Jung Antriebstechnik und Automation
© Jung Antriebstechnik und Automation
Jung presents the Fourdynamic series of its linear motor modules. Designed for strokes of up to 350 mm, the most powerful version achieves a speed of 5 m/s with an acceleration of 150 m/s2, generating peak forces of up to 2700 N. Typical assembly and machining processes for the modules include punching, bending, embossing, joining, pressing or compacting; but they are also used for dosing, stacking, sorting, feeding, testing or vibrating. The modules can perform these tasks alternately or sequentially across several processing stations - with a repeat accuracy of ±0.05 mm. A servomotor direct drive with a tubular design for connection to 400 V three-phase current is used for the drive. The drive can be freely positioned over the entire stroke range. The user has a choice of different positioning controllers with inverters, path control and interfaces to higher-level controllers and established fieldbus systems (Ethernet, Profibus, etc.). This enables point-to-point actions for simple handling processes on the one hand and movement curves for complex sequences on the other - even synchronized with other machine sequences.
3 of 14
