Touch systemAdd haptics
Extension units can be used to add haptic elements to HMI devices. There are several options for the connection - from direct hard wiring to bus-compatible communication via Profinet or Profisafe.
3 of 5
3_Fixing screws of the control element
© Siemens
... then the control element is screwed on from the inside using the threaded ring supplied ...
3 of 5
