ipf electronic
Transmitter for the top-hat rail
With the BA870100, ipf electronic presents a programmable or configurable measuring transducer in a top-hat rail housing for simple processing of analog values.
The BA870100 programmable or configurable measuring transducer from ipf electronic
© ipf-electronic
To connect a variety of possible input signals, the measuring transducer from ipf electronic integrates two optionally linkable analog inputs, either voltage or current (0 to 10 V, 4 to 20 mA, 0 to 20 mA), with freely selectable units as well as an external teach input with optional zero point function. A total of four digital outputs and a scalable analog output, which can be used as a voltage and current output (0 to 10 V, 4 to 20 mA), are used to pass on the signals. The outputs can be assigned to any input as required. A 10-bit A/D converter ensures the appropriate resolution of the required signal. It is also possible to switch the output signals in any desired form (NPN/PNP, normally closed/ normally open function, time functions). Configuration takes place via the intuitive operating concept, using three pushbuttons to navigate through the operating structure on the color TFT display.
Vega
Level measurement under extreme temperatures
Vega's high-temperature version of the 'Vegapuls 6X' radar sensor is suitable for processes at temperatures of up to +450 °C, such as iron briquetting, in which porous sponge iron mass passes through heat-resistant roller presses at temperatures of...
