ipf electronic
Transmitter for the top-hat rail
With the BA870100, ipf electronic presents a programmable or configurable measuring transducer in a top-hat rail housing for simple processing of analog values.
To connect a variety of possible input signals, the measuring transducer from ipf electronic integrates two optionally linkable analog inputs, either voltage or current (0 to 10 V, 4 to 20 mA, 0 to 20 mA), with freely selectable units as well as an external teach input with optional zero point function. A total of four digital outputs and a scalable analog output, which can be used as a voltage and current output (0 to 10 V, 4 to 20 mA), are used to pass on the signals. The outputs can be assigned to any input as required. A 10-bit A/D converter ensures the appropriate resolution of the required signal. It is also possible to switch the output signals in any desired form (NPN/PNP, normally closed/ normally open function, time functions). Configuration takes place via the intuitive operating concept, using three pushbuttons to navigate through the operating structure on the color TFT display.
