Transmitter
Quelle: E+E Elektronik | Inka Krischke,
Precise measurement in the outdoor area
With the EE33-M humidity and temperature transmitter, E+E Elektronik is expanding the EE33 transmitter series.
© E+E
According to the supplier, a heated humidity sensor, additional heating of the humidity sensor and a separate temperature sensor ensure precise measurement results even with permanent high humidity. In addition, a special coating protects the humidity sensor from contamination. The core of the transmitter is the HMC01 humidity sensor developed using thin-film technology. This monolithic sensor combines the humidity and heating element on a common substrate. The dual heating system (sensor and probe heating) prevents condensation on the sensor and the humidity probe. This minimizes the response time and ensures rapid recovery under condensation conditions.
The use of radiation protection is essential outdoors. The special design of the transmitter's sensors makes them suitable for use with a forced-air radiation shield such as the LAM630. The transmitter calculates all RH and T-related parameters such as dew point temperature, absolute humidity and mixing ratio. With the optional RS485 interface, a network of up to 32 transmitters can be set up.
Vega
Level measurement under extreme temperatures
Vega's high-temperature version of the 'Vegapuls 6X' radar sensor is suitable for processes at temperatures of up to +450 °C, such as iron briquetting, in which porous sponge iron mass passes through heat-resistant roller presses at temperatures of...
