Telemeter
Inka Krischke | Tiffany Dinges,
Operation significantly simplified
According to supplier Telemeter, the PM Plus temperature controller from Watlow has a powerful control system with many new functions.
© Telemeter
Operation in particular has been significantly simplified thanks to an interface with a color display and sliders. With the Bluetooth function, the controller can be remotely controlled and configured using a mobile device. Existing controllers from the 'PM' series can also be easily replaced with the 'PM Plus' controller version.
According to Telemeter, versions with integrated power electronics are also available. All interfaces are compatible with common hardware such as sensors and power controllers.
Endress+Hauser
Measuring gas made easy
The Prosonic Flow G300/500 ultrasonic flowmeter from Endress+Hauser is used for gas measurement. Thanks to the condensate-insensitive sensor design, the device delivers highly accurate measured values even with moist or wet gases, according to the...
Heidenhain
Long awaited
Heidenhain used SPS 2019 to present EnDat 3. Herbert Reiter, Product Manager Encoders and Electronics at Heidenhain, explains what the enhanced interface for rotary encoders, angle encoders and linear encoders can do.
AMA Innovation Award 2025
Submit applications now
The AMA Association for Sensors and Measurement (AMA) is calling on scientists and developers from industry and research to apply for the AMA Innovation Award 2025. We are looking for research and development results in sensor and measurement...
Janitza
Management expanded
Axel Hessenkämper joined Janitza as the new Chief Executive Officer (CEO) on September 1, 2024 and is part of the management team alongside Mr. Janitza, Mr. Müller and Mr. Veidt.
