AMO
Operating cobots safely
AMO's measuring devices measure position values with deviations of less than 1 µm per signal period, which enables precise positioning of robot axes and thus the safe operation of cobots in close proximity to human workers.
© AMO
The position values determined by the encoders are also redundant - two independent values are generated in the encoder for each measurement. In this way and through the additional transmission of error bits to the higher-level control system, measurement errors are eliminated. The absolute encoders have been certified for use in safety-related applications.
As a service for robot manufacturers, the encoders have a so-called mechanical fault exclusion: the safe mechanical connection of the encoders to the drive unit of numerous applications has been tested and confirmed by a type examination. This eliminates this process for robot manufacturers. According to AMO, the absolutely functionally safe encoders are equipped with purely serial single-encoder interfaces (EnDat 2.2 or Drive CLiQ).
OnRobot
Grasp like a gecko
With the Single Pad Gecko gripper, OnRobot is launching a compact version of the 'Gecko' gripper, which is particularly space-saving and lightweight. It is designed for three different payloads.
Exner
Robot programs itself
Robot welding processes have been unprofitable in steel construction to date. This has changed with a solution in which the robot programs itself and then welds each component immediately.
Zimmer Group
Robots automate machine tools
In order to increase productivity in production, more and more companies are deciding to interlink and automate their machine tools. The right automation system is crucial. Robots and the right gripping technology play an important role here.
Janitza electronics
Say goodbye to load peaks
Peak loads are expensive. Even one-off 'slips' cause additional costs in the five-figure range. However, the obvious solution of temporarily switching off large consumers such as heating systems must not compromise process reliability. Modern...
Yaskawa
More power for the Cobot
With the Motoman HC20DT IP67, Yaskawa is expanding its current range of collaborative robots with a significantly larger model that is designed for a higher payload and an extended working range.
