Product presentationsNews from measurement technology
What innovations are there for industrial users on the measurement technology market? Computer&AUTOMATION has summarized a selection of new products in a series of pictures
Torque And More presents two non-contact force sensors. The A3-P sensor system is suitable for measuring torques as well as bending and axial forces. It offers automatic system initialization, compensation functions, a feature-rich PC communication interface with integrated signal processing, graphical signal display and an integrated SD card data memory. Measurements can be taken at a distance of up to 3 mm from the shaft. The system can be used again and again in different applications. The A3-Lite S is intended for static applications to measure bending and torque forces on ferromagnetic objects (for example: shafts, solid and hollow shafts, beams). According to the manufacturer, it can be used with any object size. The measurement result - with 100 measurements per second - is available at a 0 to +5 V analog output (BNC socket).
