Jumo
Electronic thermostats on the rail
The electronic thermostat for DIN rail mounting 'Jumo eTron T100' has been specially developed for temperature control and monitoring. As an option, it can also be used for thermostatic functions for more demanding control processes.
© Jumo
The Jumo thermostat has a timer, data logger, service and operating hours counter, a PhotoMOS output for additional limit value signaling and a digital input, all integrated into a compact design. Digital control signals can be used to create logical operations (AND, OR, XOR) and process them internally. In addition to the input signals for resistance thermometers and thermocouples, a 0(4) to 20 mA measurement input is also available for connecting other process variables. In addition to UL approval, the device also complies with category 1B standards for the railroad industry. Relevant measurement inputs have been integrated specifically for the requirements of this industry, for example Ni1000. The thermostat has a configurable dot-matrix display for displaying process values, parameters, switching states and the electrical connection diagram. A clearly structured operating concept supported by additional texts, for which four languages are already available in the device, and quick wiring via vibration-proof push-in terminals enable simple commissioning. Alternatively, configuration can also be carried out via a setup program and the standard micro USB interface.
Sick
Award for sustainability management
Sick has received a platinum medal in the EcoVadis sustainability ranking. This puts the provider of sensor-based automation solutions in the top 1 percent of more than 130,000 companies worldwide that have been assessed over the past twelve months.
