Cloud communication
Filiz Elmas, Christoph Legat | Meinrad Happacher,
The reference model for a cloud federation
The number of cloud platforms in the industrial environment is constantly growing. But how can the necessary interoperability between field devices and different platforms be ensured? DIN is currently developing a standard to ensure this.
From data to knowledge: Smart applications form the basis for innovative business models and services.
© Shutterstock
There has been a lot of movement in the cloud provider market for some time now: A large number of providers are entering the market - with their own infrastructure or platform solutions as well as cloud services for machines and systems. A segmentation of the market can be observed more and more: Increasingly, mechanical engineering companies and component manufacturers are also offering their own cloud-based systems and services. In some cases, these require component or machine data or even access to machine functions to be available to the respective manufacturer in order to provide the service.
DIN SPEC 92222: a reference model
It is now becoming increasingly necessary to build a consensus for communication and data exchange between field devices and the cloud systems. This consensus building is referred to below as 'industrial cloud federation'.
From a technical perspective, industrial cloud federation encompasses communication from field or edge components to the cloud of a system operator as well as in the opposite direction. On the other hand, industrial cloud federation also describes cross-company communication between different cloud systems (technological) or cloud systems controlled and/or operated by different companies (organizational).
© Expleo
In order to achieve broad acceptance of the Industrial Cloud Federation, it is necessary to define a common standard for interoperability with the broadest possible user base. Expleo has therefore initiated the development of a new DIN SPEC 92222 for a 'Reference Model for Industrial Cloud Federation' together with customers and partners. Part of the complexity here is to develop a common consensus between different stakeholders - plant operators, component manufacturers, machine and plant manufacturers, providers of smart applications, providers of cloud infrastructure and cloud platforms - and to answer the key questions for these interest groups.
DIN SPEC 92222: It is intended to answer a whole series of questions for the respective interest groups.
© Expleo
Rapid provision of the standard to the public is necessary in order to implement data-driven applications and innovative new business models cost-efficiently and to enable investment security for all stakeholders involved. An agile standardization approach in the form of a DIN SPEC was therefore chosen.
29 institutions are currently involved in the development of the DIN SPEC: 22 companies - industry giants and SMEs from all the stakeholder groups mentioned, four associations and three research institutes of the Fraunhofer Gesellschaft. In order to achieve the ambitious goals, the following in particular
  • collect and prioritize concrete use cases from the workshop participants that are related to the Industrial Cloud Federation
  • determine the standardization requirements for implementation
  • define the solution patterns for implementation
  • and evaluate the content of the standard.
The role of OPC UA
As part of the activities of DIN SPEC 92222, particular attention will be paid to minimizing the number of technologies, norms and standards to be used. DIN SPEC 92222 focuses exclusively on the area of Industrie 4.0 - manufacturing, production, mechanical and plant engineering - and will be integrated into the existing standardization landscape and recommendations of relevant committees.
In this context, OPC UA represents a promising starting point for Industry 4.0 - not least because OPC UA has been recommended by the Industry 4.0 platform and defined as a prerequisite for Industry 4.0 components. As part of the work on DIN SPEC 92222, the OPC UA standard was intensively examined with regard to its suitability for the Industrial Cloud Federation. One of the key findings: Telemetry - the transmission of measured values to a cloud - is already covered within the OPC UA standard at a solid level of maturity for Industrial Cloud Federation. As part of DIN SPEC 92222, aspects such as the routing of data across cloud systems must now be examined in more detail. The situation is different for functionalities that go beyond telemetry, such as access from the cloud for querying the OPC UA information model or calling methods. There is a need for standardization for the industrial cloud federation here.
OPC UA is independent of a specific transport protocol and can therefore be used on the basis of different protocols - TCP, MQTT or AMQP. The standard also evaluates and defines which transport protocols should be used for which application.
The LNI 4.0 Cloud Testbed
The 'Cloud2Cloud' testbed was initiated in collaboration with the Labs Network Industry 4.0 to ensure the practical suitability of DIN SPEC 92222. Here, various partners are testing specific use cases for SMEs in a pre-competitive environment in order to implement the new standard and associated framework conditions in practice in a cost-effective and low-risk manner.
DIN SPEC 92222 is expected to be published in the first quarter of 2019 and will be available to download free of charge from Beuth Verlag.
Authors:
Filiz Elmas is Project Coordinator Digital Technologies, Digital Technologies Department at DIN;
Dr. Christoph Legat is a software professional at Expleo in Germany.
Miba
The first steps towards digitization
Real-time transparency in the material flow: this was the goal set by Miba when it set out to digitalize its internal logistics processes. But how successful was the close link between ERP and MES in the end? - A field report.
Big Data
Online machine data under control
Turning huge amounts of data into valuable information - how can this smart industry approach be implemented? Linking PC-based controllers with Matlab and a cloud-based IoT analytics service can be a viable approach.
Control / Rules
From modeling directly into the PLC
Despite digitalization and I4.0, the technical functions in a process plant do not become simpler if you break them down to the smallest detail. Nevertheless, the high level of difficulty can be overcome by combining the right tools in the right way.
Industry 4.0
Why predictive maintenance?
Investments in predictive maintenance systems are worthwhile in order to proactively detect damage. Not only does this increase the service life of a machine, it also opens up new business models for machine manufacturers.
Industry 4.0
First customer projects via BaSys 4.0
The BMBF project 'Basissystem Industrie 4.0' expired at the end of June 2019. Together with NetApp and Objective Partner, Fraunhofer IESE now offers Industry 4.0 solutions with support and adaptation to customer systems on the basis of this project....
