iniNet Solutions
Industry 4.0 'off the shelf'
iniNet Solutions has developed an automation architecture based on web server-supported SCADA and programming software that is designed to bring manufacturing companies up to Industry 4.0 level more easily than ever before. It can be seen at the SPS.
Peter Brügger, iniNet Solutions: "With our solution, our own permanent staff can easily program Industry 4.0 applications."
© WEKA Trade Media
"The biggest challenges on the path to Industry 4.0 lie between the automation and IT worlds," explains Peter Brügger, Managing Director of iniNet Solutions. "Two worlds collide - and this problem needs to be solved." With its new hardware and software architecture, the company aims to merge the two worlds into one productive unit.
According to Peter Brügger, the production processes must be programmed exclusively at the automation level in order to avoid redundancies: "The control level determines which orders are to be processed and which products are to be manufactured. It also issues the requirements for production equipment, production times, parts lists, test protocols and much more. This also means that the control level determines what is to be produced - but how it is to be produced is determined by the machine."
At the production level, the approach is therefore as object-oriented as possible, in the sense of focusing on the machine as a mechatronic unit. "The respective production and control units therefore retrieve the orders from the control level, communicate with the subsystems required for product manufacturing, allocate them and provide them with the link to the specifications from the control level," explains Peter Brügger. Material requirements and consumption are reported to a logistics system and the production status is sent back to the control level. Each object deals exclusively with its own task. "This means that not only the I/O level for classic automation is programmed for each control system, but also the communication level for integration into the company's Industry 4.0 network." For each product that is then manufactured, programming is carried out as 'classically' as possible in IEC 61131 at the I/O level of the automation systems.
The SCADA software 'SpiderControl SCADA Server', which is available for various operating systems, forms the basis for setting up the control unit. If the SCADA server is integrated in the PLC, it can communicate directly with the local PLC application or with remote automation components. The 'SpiderPLC' programming tool is integrated into the SCADA server, which enables programming with a function block diagram in accordance with IEC 61131 via the browser. The special feature: "The function blocks not only execute simple logic, but can also call up functions from external scripts in the most important current high-level languages, including JavaScript, i.e. NodeJS and NodeRED, PHP, Python and .NET," says Peter Brügger. A runtime for executing the required script languages is also installed in the PLC for this purpose. The runtime is started in the background and waits to receive a request to execute a function from SpiderPLC.
This makes it possible to link the PLC code directly with the data and functions from the control level. To connect to the IT level, the computer scientists can provide the code for communication with their applications in the high-level language of their choice. This code is encapsulated via a function block and integrated into the automation.
"Common processes can therefore be easily implemented on the basis of the SpiderPLC/SCADA infrastructure," concludes Peter Brügger. "The decisive advantage is that the programming of Industry 4.0 applications can easily be carried out by the company's own permanent staff." The classic problem of the rift between the automation level and IT is also elegantly solved because both sides can remain in their technical domains: "IT provides all relevant interfaces in a programming language that it is familiar with. The automation level uses these as function modules in function block diagram programming, which has access to all automation components via the SCADA and its drivers."
OPC UA
On the way to the world library
The vision has been in place since the end of 2014: OPC UA is to achieve the status of a globally recognized standard for the Industrial Internet of Things IIoT by 2019 at the latest. During the press conference at SPS, the Foundation took a stand...
Turck
More investment in software expertise
The economy is leaving its mark: compared to the previous year, Turck expects total sales of around 640 million euros for the 2019 financial year, a decline of 3%. Nevertheless, Managing Director Christian Wolf is optimistic.
SPS 2019
A look back at the fair
The 30th SPS was the highlight of the automation industry at the end of November. The keywords 'digitization' and 'digital transformation' were visible right through the halls. The main trends can be seen in the film below.
Video
SPS 2019 in retrospect
The 30th SPS, the trade fair highlight of the automation industry, took place at the end of November. The buzzwords 'digitalization' and 'digital transformation' were visible throughout the halls - the most important things in the film.
Sieb & Meyer
Dynamically driving high speed motors
Under the name SD4x, Sieb & Meyer is developing a new generation of frequency inverters for high-speed applications. The first of these is the SD4S version, which is designed for small high-speed spindles and motors with a power output of just a...
IniNet Solutions
iniNet Solutions has developed an automation architecture based on web server-supported SCADA and programming software, which is intended to bring manufacturing companies more easily than ever to industry 4.0 level. This architecture can be seen at...
CloudRail
Plug and play into any cloud
A year ago, Cloudrail unveiled the 'CloudRail.Box' for the first time - a gateway that connects plug-and-play to IO-Link sensors and masters and sends the data to any cloud platform. Now it also handles OPC UA and Edge Computing.
R3 Communications
Manufacturing without cables
R3 Reliable Realtime Radio Communications presents its first series products "Echoring Ethernet Bridge" (EREB) and "Echoring System on Module" (SoM) at the SPS. They are intended to complement wired industrial Ethernet networks with equally powerful...
