Product picture galleryNews from the field of big data
As part of the big data trend, many new products are coming onto the market - from boards, gateways and data loggers to software and security solutions.
9 of 18
icom Data Suite software package from Insys Microelectronics
© Insys Microelectronics
With the icom Data Suite, Insys icom offers a flexible software package for the MRO and MRX router series that supplements the devices with functions for recording and processing application data. The current version 1.2 of the software enables the processing of Lua scripts and opens up its functions for Codesys controllers and networks. This means that the software can be used to efficiently integrate and network Codesys controllers or other devices based on the runtime environment into infrastructures via TCP (V2/V3) and via Codesys Gateway Server (V3). Parallel access to other instances (e.g. WebVisu or programming tools) is still possible. By networking and processing data points, a large number of software-based applications can be implemented quickly and without special programming knowledge via configuration. The data from Codesys controllers and devices is recorded independently of protocol and manufacturer. Logic and arithmetic functions are available for processing the data. Status monitoring applications can also be implemented using timers, flags and an event handler. Current values can be visualized via a local dashboard that can be accessed via a browser and transferred to SCADA, ERP systems or clouds. In addition to comprehensive visualization, functions such as logging or reporting are also available there.
9 of 18
