Bosch RexrothctrlX Automation ecosystem
The real-time capable, Linux-based operating system ctrlX OS from Bosch Rexroth, which was previously used exclusively on the ctrlX Core controller, is now available as a separate solution for the industrial environment.
As a prelude to the growing i³ Control portfolio, Yaskawa is presenting the first PLC in the i³ Control complete solution: the iC9210-PN. Also new are the CR700 crane inverter and the LA500 lift inverter. The Ethernet-based multi-protocol card is now available for the GA500 and GA700 series inverters, which enables four protocols on one card and thus makes commissioning more flexible. The compact SLIO system (decentralized I/O system), which offers numerous modules for input, output, function and power, is also new to the portfolio. The combination of SLIO modules with a CPU and matching I/O system combines functionality with an intelligent mechanical concept in a compact and maintenance-friendly design. The 'ecosYstem' of the Cobot portfolio, which offers a variety of grippers, peripherals and other accessories, is designed to make entry into robot automation smarter and easier.
SPS 2022: Hall 7, Stand 340
