KEB Automation at the SPS
Deploy industrial IoT capabilities at scale
The Network of Automation, or KEB NOA for short, is a scalable digital ecosystem with industrial IoT capabilities that connects machines, people and processes directly on one platform.
© KEB Automation
According toKEB Automation, it not only improves production and service processes, but also creates complete transparency of existing machine and process data. 'KEB NOA' delivers data to a cloud via the IIoT connection, where it is structured, analyzed and combined with existing knowledge.
Intelligent algorithms, machine learning and AI enable condition monitoring and predictive maintenance, for example. Unwanted trends or problems are identified using big data analysis functions, and appropriate countermeasures are taken based on expert knowledge.
KEB Automation
Control drives safely
Functional safety is intended to minimize the risks posed by technical equipment to people and the environment. The drives from KEB Automation offer scalable safety functions directly in the drive controller for this purpose.
KEB Automation
Use in disk motors
The Combistop 38 spring-applied brake from KEB Automation is often used as 'Version 38S' in disc motors, for example. Its reduced overall length allows it to be used even in tight installation spaces.
