Jumo
Supplemented by three modules
The Varitron automation system from Jumo is being extended by three modules: The 32-channel digital I/O module offers 32 channels, 17 of which are configured as digital outputs as standard.
© Jumo
Up to three optional plug-in cards can be used to add five digital inputs or outputs each.
The digital input signals can be further processed in the 'Varitron' central processing unit; LED displays visualize the switching statuses.
The 2-port router module adds two system bus outputs to the central unit of the automation system. This allows the system bus to be transmitted to the new 3-port router module on other top-hat rails in the same or in other control cabinets at a distance of up to 100 m. According to Jumo, this enables input and output modules to be distributed and the automation system to be arranged decentrally.
Addressing via rotary coding switches can be implemented for special applications. With all three products, the operating voltage and system bus can be wired quickly by simply plugging the modules together.
Would you like a little more?
First-hand news every week - that's what the Computer&AUTOMATION newsletter offers you.
© WEKA Trade Media
Subscribe to our newsletter and keep your finger on the pulse of automation. Stay up to date with us. We provide you with the latest news, exciting interviews, guest commentaries, application-oriented technical reports and new products.
Click here to subscribe.
Jumo
Horizontal version
The Nesos R40 LSH from Jumo is a new member of the Nesos series, which includes devices for point level measurement using a float and reed contact and for level measurement using a float and reed chain.
Jumo
Continuously measured
Safety PLCs are not always necessary to implement safety requirements in tank systems. In some cases, the use of safety monitors or limiters is also sufficient.
Jumo
Use in hazardous areas
Especially in chemical or process engineering processes, additional heating is required to maintain or increase the temperature in order to optimize the complex processes of modern industrial plants. But what needs to be considered here?
Three questions for ...
Trends in robotics
Under the title "Three questions for ...", computer-automation.de is publishing short interviews with the leading figures in the automation industry on a regular basis this year. This month, the focus is on robotics.
