Advertorial
Conrad | Tiffany Dinges,
Products meet trends: automation technology at Conrad
Product selection, user recommendations and future topics: Parallel to the all about automation trade fair series, the Conrad Sourcing Platform also focuses on the automation of mechanical and electronic processes in industrial and logistics facilities.
© Sergey Ryzhov - stock.adobe.com
MRO professionals will find a comprehensive selection and customized services on the Conrad Sourcing Platform.
© industrieblick - stock.adobe.com
"Our selection to cover technical requirements in the fields of automation and pneumatics is huge," says Manuel Gschwend, the Conrad product manager responsible. From sensors and connectors to drive technology and power supplies: Simply fast and comprehensive, Conrad supplies exactly the automation technology it needs for the modernization, expansion, maintenance and servicing of systems. In total, more than 900,000 product offers are available on the Conrad Sourcing Platform. In addition, there are suitable product and procurement services for companies, for example for customized e-procurement, on-demand and scheduled orders or the realization of individual 3D printing projects in industrial quality.
Innovations from leading manufacturers
Professionals can also get the information they need from Conrad without any detours: The Conrad team is currently presenting its comprehensive range in the field of automation technology and its services as a reliable procurement partner at all about automation, the trade fair for industrial automation. On top of this, the Conrad team will be spotlighting new products from well-known manufacturers in its Automation theme world: the new Compact Controller from Wago, for example, combines compact control and I/Os in one housing. The eSIGN signal tower with integrated siren from Werma sets new standards in terms of visibility. And Siemens is presenting its new industrial IoT gateway for implementing a wide range of applications as well as a new PLC expansion module that focuses on communication via different protocols.
Product ranges and trends at a glance
Everything from a single source: In a dedicated Conrad theme world, there are innovations, trends and tips for the automation of mechanical and electronic processes.
© Surasak - stock.adobe.com
"We have pooled our expert knowledge in our automation topic area, recommend special automation products and provide advice on specific user examples such as field and process technology, control cabinet and special machine construction or digitalization," reports Manuel Gschwend. Companies can also find exciting articles on future topics such as edge computing and machine learning, remote maintenance and industrial Ethernet, modernization and plant expansion, decentralized automation and robotics.
More stable networks and increased system availability
The design of automation systems is one of the most important topics in operational digitalization. Decentrally organized automation systems break down rigid hierarchies to give autonomous units the authority to make independent decisions. Systems and machines that can operate autonomously relieve the burden on the central control system and bring more security and stability to complex processes. In addition, cabling over long distances and distribution in control cabinets are largely eliminated. This means a reduction in potential sources of error and therefore also in maintenance and servicing costs.
The advantages of decentralized automation are obvious: ultra-fast process control, avoidance of long cable runs and more stable networks.
© Henrique Silva - stock.adobe.com
Unmanaged switches for basic and standard applications
Unmanaged switches are a cost-effective, uncomplicated and secure solution for smaller companies. Installation is similar to a plug-and-play installation process. Depending on the version, the switches have fiber optic interfaces and SFP ports for greater flexibility. Thanks to quality of service functionality and multicast filters such as PTCP, they achieve improved prioritization of data traffic in Profinet and Ethernet/IP networks. This also helps to stabilize the network and increase system availability. The manufacturer Phoenix Contact, for example, offers the 1000 and 1100 series of unmanaged switches, which also support high-bandwidth applications.
Secure fast cabling for industrial networks
Data managed in production plants for plant automation and manufacturing applications is transported via Ethernet-based industrial networks. The performance of these networks is only as good as the cabling technology allows, and particularly high demands are placed on the installation of cabling in industrial environments. Siemens offers a system that meets all these requirements: with FastConnect, a sophisticated quick installation system has been developed for fast and error-free installation on site.
Power supply for automation
The cabling technology of the power supply must also meet special requirements. A high proportion of malfunctions and failures are due to overvoltages. It is not only lightning strikes, defective electrical equipment in the installation, the switching off of inductive consumers or the switching on of large capacitive consumers that cause transient overvoltages. Increasing automation itself is also causing more and more problems, as potential interference sources such as drives, motors and highly sensitive control systems are increasingly being used in complex electrical installations. Standardized surge test procedures provide information on how robust and safe a power supply actually is against short-term overvoltages. In addition, the surge voltage must of course also be prevented from passing through to the secondary side. The power supplies from Mean Well, for example, are therefore often certified in accordance with the IEC/EN62368-1 safety standard and designed as overvoltage category II (OVC II). As the demand for OVC III products is increasing, Mean Well has already certified a large selection of OVC III power supply units, such as the LRS built-in power supply units or the HDR series DIN rail power supply units, in accordance with IEC/EN61558-1. More information about decentralized automation can be found here.
Overview
The top articles in May 2022
The Top 10 shows clear movements in the market: all kinds of premieres were announced and automation companies reported positive results and forecasts. In addition, interest in product trends continued unabated, as did interest in our new medium....
Overview
The top articles in April 2022
Did you miss one of this month's most exciting articles? We summarize the crème de la crème. Find out what artificial intelligence has to do with whiskey or what the situation is with PLCs in the cloud, among other things: the top 10 in April.
Overview
The top articles in March 2022
Find out in the most-read articles from March how fears of robots can be reduced, what is behind the 'PLC from the cloud', why it doesn't always have to be 'six right ones' and also news about TSN in practical implementation. The top 10 in March.
