Product presentationsNews from the world of control technology
What's happening in the field of control systems and motion control? Computer&AUTOMATION has summarized current products from the field of control technology in a picture gallery.
The PRM extension module is an addition to the akYtec 'PR200' small controller with the same performance as the basic device and eight additional digital inputs and outputs each. Up to two extensions can be installed, which increases the potential of controllable processes. Depending on the supply voltage, the extension module is available with 24 V(DC) or 230 V(AC). The device in the compact housing can be installed on a 35 mm DIN top-hat rail without tools. Thanks to its design and depth, each module can be installed not only in the control cabinet but also in an electrical distribution board. It is connected to the base unit via an internal bus.
