Current productsInnovations from the Control & Drives division
Control & Drives - i.e. controllers and intelligent drives - are the core components of automation technology. Computer&AUTOMATION shows an excerpt of current products from these areas in a picture gallery.
9 of 21
Starter kit SSK 002 from Sigmatek
© Sigmatek
The SSK 002 starter kit is suitable for an easy entry into the world of Sigmatek automation. In addition to a function-oriented CPU with digital and analog modules, the basic unit 'TSY 021' includes a mini safety solution consisting of a safety controller and digital safety mixing module. Data is exchanged via the Varam real-time Ethernet system and OPC UA connectivity is integrated. The control unit is supplemented by the 'TSY 031' human-machine interface. The 'ETT 732' panel enables convenient operation. In addition to a 7-inch widescreen with projected capacitive dual touch and Edge2 Technology processor, interfaces such as USB, CAN and RS232 are on board. Axis applications can be simulated with the motion unit. The 'TSY 041' is equipped with two axis modules for controlling servo motors, a Varan bus interface and a digital mixing module. The application is created using the 'Lasal' software supplied.
9 of 21
