Box PCs
Quelle: Syslogic | Inka Krischke,
Meets railroad standards EN50155 and EN45545
Syslogic has released a new version of the Railway Computer Compact 8, a fanless box PC specially developed for rolling stock applications.
© Syslogic
It is suitable as a data logger, FIS computer, control computer, content server, communication computer or network video recorder. It complies with the railroad standards EN50155 and EN45545. The computer is approved for a temperature range of -40 to +85 °C at component level. It also offers power failure bridging up to 10 ms in accordance with EN50155, class S2, as well as full EN61373 conformity with regard to shocks and vibrations, EMC and electrical insulation requirements. The box PC has an electrically isolated power supply input and can be configured via wide-range inputs for DC voltages between 16.8 and 110 V, including the ignition controller. The built-in CPU boards are protected against condensation with a special coating. In addition, all electronic components are permanently soldered, allowing the box PC to withstand constant vibrations. The computer is passively cooled and has an industrial SSD memory instead of a hard disk. It has two Gigabit LAN, two RS232 and two USB ports as well as a DVI port as standard. M12 connectors are used for the LAN interfaces and for the power supply. The computers can be equipped with GPS and LTE/GSM/UMTS functions for positioning and data transmission. Connection to typical railroad BUS systems such as real-time Ethernet, TCN, WTB, Profinet or MVB is made via optional expansion cards.
Logistics systems
New products for Logimat 2019
What is currently happening on the market in the areas of material flow and process management? Computer&AUTOMATION has compiled an excerpt of what exhibitors are showing at the Logimat 2019 logistics trade fair in Stuttgart in a series of...
Box PCs
IoT device for logistics
The new 'Vehicle Computer Compact M8' embedded box PCs from Syslogic have no moving parts, are shock and vibration resistant and are designed for an operating temperature range of -40 to +85 °C.
Embedded PCs
Suitable for vehicle installation
With the Nuvo-5100VTC, Industrial Computer Source presents an embedded PC that is E-Mark and EN-50155-certified and is therefore suitable for installation in vehicles. The devices are equipped with sixth-generation Intel Core i7, i5 and i3 CPUs.
Tablet PCs
Optional UPS module available
The outdoor tablet PC model 'UPC-F12C-ULT3' from Comp-Mall in an aluminum housing can be used as a mobile or stationary device and is protected against dust and splash water thanks to its all-round IP65/IP66 protection class.
