Concept International
Individually configurable
The 24 inch/60 cm All-in-One PC DT524T Black from DT Research is certified in accordance with EN 60601-1 and is therefore subject to stricter EMC controls than the usual CE certification.
© Concept
Its shock-resistant chassis is resistant to cleaning and disinfectants thanks to its aluminum alloy, its front is made of sturdy Gorilla Glass and has a 10-point touchscreen. The anti-glare display of the Panel PC shines with 300 cd/m². In addition, the capacitive touchscreen is firmly connected to the LED panel using a special bonding process.
Industrial customers can choose between full HD or 4K resolution. The device is optionally equipped with an integrated RFID reader for fast, chip-based login. The 'data center' of the tablet PC comes from the Intel Core i family: either as a dual-core Celeron or as a QuadCore i5 or i7 variant. Depending on the model, the RAM can be upgraded to up to 16 Gbyte and the local memory can be increased to up to 1 Tbyte with the help of an SSD.
E.E.P.D.
Industrial NUC box
The 'New Unit of Computing' (NUC) is an invention by Intel. E.E.P.D has made the form factor suitable for industrial use and installs processors from the 'AMD Ryzen Embedded V1000' platform in it.
IoT Hotspot
Focus on cloud and edge computing
The Eclipse Foundation, currently the largest open source organization in Europe, wants to promote global industry collaboration on open source projects in strategic technologies. Mike Milinkovich, Executive Director of the Eclipse Foundation,...
