The right CoM standardThe decisive factor is the performance class
It is not easy for developers to correctly evaluate the different form factors of the standardization bodies. Depending on the performance class, only a single standard is usually recommended for new system designs. However, there are also exceptions.
<p>Figure 3: SMARC is the low-power form factor for Arm and x86 processors that enables compact designs with a cost-effective edge card connector. Here is a SMARC module based on the NPXi.MX8-Plus processor with carrier, heatspreader and Basler camera as a kit.</p>
© Congatec
