Current productsProducts for edge and fog computing
What is currently happening in the fields of edge and fog computing? Computer&AUTOMATION shows current products in a series of pictures.
7 of 7
Ultra-compact Industrial PCs from Beckhoff Automation
© Beckhoff Automation
The 129 mm x 133 mm x 104 mm C6032 Industrial PC expands the series of ultra-compact Industrial PCs from Beckhoff with a modular device. It supplements the 'C6030' of the series, which is comparable in terms of computing power, with an additional board level for modular interfaces and function expansions. This is realized via compact PCIe modules, with which the IPC can be adapted to the respective application requirements. With 6th and 7th generation Intel Core i processors - up to Core i7 with four cores at 3.6 GHz each - the computer is suitable for extensive axis control, complex HMI applications, extremely short cycle times or large-volume data handling. The connection level accessible on the front of the device can be flexibly expanded via two PCIe compact module slots. Initially, the PCIe modules 2 x GBit Ethernet, 2 x USB 3.0, 2 x RS232 and 1 x CP-Link4 are offered for this purpose. Thanks to the use of a speed-monitored and controlled fan, the industrial PC is suitable for a maximum temperature range of +55 °C, depending on the CPU. Windows 7 or Windows 10 operating systems and a second M.2 SSD in a RAID array are optionally available. As standard, the IPC offers a storage capacity of 40 Gbyte M.2 SSD, 3D flash.
7 of 7
