Current productsProducts for edge and fog computing
What is currently happening in the fields of edge and fog computing? Computer&AUTOMATION shows current products in a series of pictures.
6 of 7
Embedded box PC Hygrolion 67 from ICO
© ICO Innovative Computer
Despite its compact dimensions of 100 mm x 115 mm x 31 mm (WxDxH), the Hygrolion 67 embedded box PC has everything it needs for easy integration into the respective network, according to manufacturer ICO. Two Gbit LAN connections and an additional WLAN connection enable combined use in machine and company networks or direct access to the internet. The computer can receive measurement data via the two integrated USB-C and USB-A interfaces as well as via Bluetooth 4.0 and, for example, process the data as an IoT gateway and forward it to the cloud server. Two additional antennas increase the range of the Wi-Fi. The VESA mounting points allow it to be attached to monitors or displays or even directly to walls or machines. An additional display port can also be used for control or monitoring tasks. An Intel Celeron N3350 with a clock speed of 1.10 GHz is used as the processor. However, the processor can also dynamically increase the computing power to up to 2.40 GHz, which is sufficient for most IoT tasks. The processor is supported by 4 Gbytes of RAM and a 64 Gbyte eMMC for the operating system and data. The computer is equipped with IP67 protection for the necessary robustness.
6 of 7
