Product presentationsNews from the industrial computer sector
What's new on the market for industrial PCs and operating systems? Our picture gallery shows you the latest products from these areas.
The Raspberry Pi is being used more and more widely in industrial electronics and has now arrived in the world of PLC systems: Mass presents the new RPi07-Xtend development as a first expansion stage. In addition to the usual functions of digital and analog I/Os and various interfaces, the complete PLC controller also includes an operating and display system as well as the previously separate programming device as an "all-in-one" system. The robust stainless steel housing contains a 7-inch widescreen multi-touch LCD with a resolution of 800 x 480 pixels for 10-finger operation, embedded in an aluminum front frame. The CPU unit is the Raspberry Pi '3B+' with its ARM Cortex A53 with 4 x 1.4 GHz. With the integrated I/O and interface expansion module 'PiXtend v2-S' from Qube Solutions, this panel PC is a complete "low-cost PLC". The CPU contains 1 Gbyte RAM, a micro SD card (16 Gbyte or larger) with operating system and application software. The board also has connections for HDMI, CSI camera, video/audio and post connectors for I²C. The Ethernet has 1 x 10/100/300 Mbps; there are also four USB 2.0 ports. The PLC is designed for eight digital inputs, four digital outputs, four PWM/servo outputs, four 230 V relays, two analog voltage inputs and outputs, one RS232, real-time clock (RTC) and four GPIO. The connection voltage of the industrial power supply unit is 12/24 V(DC). The 'Raspbian' operating system offers support for Linux, Codesys, FHEM, Phyton, Node-RED and OpenPLC. The device protection class is IP54.
