New productsNews from the industrial computer sector
What's new in industrial PCs? Our picture gallery shows you the latest products in this area - from conventional embedded devices to USB hubs and specially enhanced Raspberry Pi devices.
The fanless F105D from Giada uses the quad-core Intel Celeron N3450 processor (Apollo Lake) with up to 2.2 GHz and a power dissipation of just 4 W (SDP, TDP: 6 W). According to the manufacturer, it ensures more efficient encoding of H.265 and VP9 video formats thanks to the latest Skylake graphics. Thanks to the dual-channel architecture, a performance increase of around 30% is possible by equipping it with a second 2 GB DDR3L memory module. The F105D also has two Mini-PCIe slots (full-length SSD; full-length Wi-Fi/BT module). The common operating systems Windows 10 and Linux are supported. With a total of three monitor outputs, HDMI 1.4b, DisplayPort 1.2 and VGA, the mini computer is compatible with any type of monitor. Up to two monitors can be controlled simultaneously. A VESA-compatible, lockable bracket for wall or monitor mounting is optionally available. The integrated Intel HD 500 graphics ensure a maximum image resolution of 4K/UHD (4096 × 2160 pixels at flicker-free 60 Hz via DP). The Mini-PC measures 190 mm × 149 mm × 26 mm and, with three USB 3.0 ports, two USB 2.0 ports and a serial COM port, offers numerous expansion options for a wide range of application requirements.
