New productsNews from the industrial computer sector
What's new in industrial PCs? Our picture gallery shows you the latest products in this area - from conventional embedded devices to USB hubs and specially enhanced Raspberry Pi devices.
14 of 17
Model Tank-610-BW from Comp-Mall
© Comp-Mall
The Tank-610-BW model from Comp-Mall with the 2.24 GHz quad-core Celeron N3160 processor from Intel operates in the -40 to +60 °C range. According to the supplier, the fan-free embedded PC is specially designed for applications in the field of machine control and automation technology. The system can be upgraded with up to 8 GByte DDR3L SO-DIMM, a 2.5-inch SATA HDD/SSD and mSATA. Two PCIe GbE interfaces and optional WLAN are designed to guarantee secure data transfer. The model enables dual-display operation via the VGA and HDMI output. It has one full-size and one half-size PCIe mini slot internally for expansions - for example for a WLAN module. The system also offers an AT/ATX wide-range power supply from 9 to 36 V(DC) and vibration and shock resistance of Mil-STD-810F 514.5 C. The dimensions are 201 mm × 184 mm × 59 mm - mounting brackets are included and mounting via VESA100 is also possible, allowing the computer to be mounted in a cabinet, on a wall or in a vehicle. On customer request, the company can also supply the system with a pre-installed Microsoft Embedded Standard 7E and HDD/SSD.
14 of 17
